  • Sittichai R. 2 posts 72 karma points
    Aug 18, 2019 @ 06:21
    Sittichai R.
    Please help, OutOfMemoryException: Array dimensions exceeded supported range.
    Dear, I got source code from my supplier to install in my web server: - windows server 2016 - iis - mssql express - umbraco 7.7.9 (see in web.config)
    I got the error OutOfMemoryException: Array dimensions exceeded supported range. you can see all error message at http://203.150.8.157/
    Can anyone help?
    Best regards,
  • Shaishav Karnani from digitallymedia.com 353 posts 1637 karma points
    Aug 19, 2019 @ 06:47
    You need to rebuilt Index again and then your site will work fine. Also check you have enough hard disk space to rebuilt Index.
    Also rebuilt your Umbraco.config
    Hope this helps and let me know if you need further assistance.
    Regards,
    Shaishav
    https://www.digitallymedia.com
    Aug 20, 2019 @ 15:27
    Sittichai R.
    Dear,
    Thanks for your response.
    As I never touch Umbraco before and after searching how to rebuild index in google.com. I found command to do it but I have no idea where to put the command. Could you please give me step-by-step?
    Some ask to go into backend, I not sure that is it http://203.150.8.157/BackOffice it also shows error anyway.
    Configuration Error Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
    Parser Error Message: It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS.
    Line 81:
    my skype is limparty. If you want to chat with me for real time response.
    Thanks in advanced
    Best regards, Lim
  • Tarik | WPPlumber 179 posts 781 karma points c-trib
    Aug 19, 2019 @ 07:28
    Tarik | WPPlumber
    As you mentioned in your post and from the error page seems for me you're using a source code solution.
    C:\projects\examine-qvx04\src\Examine\LuceneEngine\Providers\LuceneIndexer.cs:765
    I suggest that you follow the steps mentioned by community guide to build the project.
