I have to convert JSON to XML using XSLT 1.0. I have tried XSLT 3.0 but it doesn't work for me.
Request:
{ "Text": [ { "from":"784494", "to":"744111" } ] }
Expected Response:
<?xml version="1.0" encoding="UTF-8"?> <Text> <from>9878744785</from> <to>998777945</to> </Text>
XSLT I tried:
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:xs="http://www.w3.org/2001/XMLSchema" exclude-result-prefixes="xs" version="3.0"> <xsl:output indent="yes"/> <xsl:template match="/"> <xsl:copy-of select="json-to-xml(root)"/> </xsl:template> </xsl:stylesheet>
I never heard of Gateway script before. I googled it and found this:
https://www.ibm.com/docs/en/acfc?topic=gatewayscript-code-examples
How to convert JSON to XML using XSLT 1.0/2.0 ?
Request:
Expected Response:
XSLT I tried:
