  • Mayur Sorathiya 12 posts 83 karma points
    Feb 23, 2022 @ 05:33
    Mayur Sorathiya
    How can I clone Umbraco Heartcore Project?
    How can I clone this project to my local machine? There is no clone project option available.
    How can I clone this project to my local machine? Please guide us.
  • Lindow 154 posts 1301 karma points
    Feb 23, 2022 @ 07:09
    Lindow
    Hi there.
    That option doesn't exist on a heartcore project, as it's a SaaS product.
    Feb 23, 2022 @ 09:01
    Mayur Sorathiya
    Thanks for the answer.
    So, my question is How can I setup it locally for development?
    Feb 23, 2022 @ 09:12
    Lindow
    You can't. That's not an option.
    You can only work with Heartcore in the backoffice on Umbraco Cloud.
    Feb 24, 2022 @ 07:05
    Mayur Sorathiya
    Hi Lindow
    Thanks for the feedback and I am also going with documents. so now we decide to go with Umbraco Cloud version. We need to deploy 8 website within one plan. 1 main website has other 7 divisions for 7 divisions we need to develop separate websites and linking each other. so is it good option to go with Cloud version?
    Can we create 8 website within 1 account?
    Feb 24, 2022 @ 09:56
    Lindow
    Yes, you can create a site like that. The major downside here is that they all go down if the project is down for some reason, as they're hosted on the same application.
    For that, you could create a root node where each of them is a separate website and then assign a hostname to each of them via the culture and hostnames setting in the backoffice.
    Try searching for "multi tenant Umbraco solution" on the internet and you should be able to find a couple of guides :)
    Feb 24, 2022 @ 10:45
    Mayur Sorathiya
