I have one query over here. As you can see in a red box we have two documents but once we live then there will be many documents. So I want to do one thing like recently added document should come first. so every time when I add a new document then it will come to the top.
The list view in the backoffice sorts the content nodes by last edited DateTime, so it won't be possible to achieve in the backoffice but you can easily sort them on your frontend by using either the createDate or sort properties :)
Recently Added document display First.
It's this possible?
Hi there.
Thanks Lindow
