  • Pete 152 posts 176 karma points
    Jul 02, 2010 @ 18:14
    Pete
    Event for Next button click
    Is there an event for the Next button click? If so, what is it? :)
  • Jamie Howarth 306 posts 773 karma points c-trib
    Jul 02, 2010 @ 23:48
    Jamie Howarth
    Hi Pete,
    Which "Next" button are you referring to?
    Benjamin
  • Harald Ulriksen 207 posts 249 karma points
    Jul 03, 2010 @ 00:12
    Harald Ulriksen
    Partially submitted should do the trick. For back button it's resumed, but it does not fire on the first back click, only on 2nd -> n . If you need full control I suggest you inherit from the renderform and override that std. button-click events. [edit: prev and next page methods is not available when overriding RenderForm]
    Hope this helps, Harald.
    Jul 05, 2010 @ 13:25
    Pete
    Thanks Harald, PartiallySubmitted is what I was looking for. For some reason it wasn't hitting the breakpoint on Friday but is now.
