  • Pete 152 posts 176 karma points
    Jul 06, 2010 @ 11:28
    Pete
    No values from step one saved, no values when click previous
    I have a form with two steps, the first step has 3 radiobuttonlists and one textbox, the second step just has one text box.
    If I fill out the first step, go to the second step then press "Previous" step one does not preserve the values I've entered.
    If I complete the form, only the value from the step 2 textbox is saved.
    I had spent hours trying to work out how to access the step one values in an EventHandler but this may well be why I can't get at them!
    Contour 1.0.9
    umbraco v 4.0.4.1 (Assembly version: 1.0.3793.17632)
  • Comment author was deleted
    Jul 06, 2010 @ 11:34
    Hi Pete,
    That was a bug that got into the 1.0.9 release.
    I would recommend that you upgrade to the latest version of Contour. You can get the latest version here: http://nightly.umbraco.org/Umbraco%20Contour/ (currently 1.0.12)
    Upgrade instructions (simply update all Contour files):
    Use one of the zip files which ends in _update.zip
    This is a normal zip file you can unzip in the root of your site,
    which will ensure that the contour files are updated to the newest
    version.
    Tim
    Jul 06, 2010 @ 11:53
    Pete
    Brilliant, thanks Tim. I realised I just scanned to the bottom of the download list and grabbed 1.0.9 not realising 1.0.10+ were at the top due to text ordering.
    I can now see the records in the EventHandler (thank goodness!) and the values are showing in the entries in the CMS.
    Radiobuttonlist values are not persisting on Previous though. The textbox value is.
