The Error: System.InvalidCastException: Specified cast is not valid. at Umbraco.Forms.Data.Storage.RecordStorage.GetRecord(Object id) in d:\TeamCity\buildAgent\work\f25907cf379d8816\Umbraco.Forms.Core\Data\RecordStorage\RecordStorage.cs:line 83 at Umbraco.Forms.Library.GetRecord(String recordId) in d:\TeamCity\buildAgent\work\f25907cf379d8816\Umbraco.Forms.Core\Data\Library\Library.cs:line 72 --------------------------------------------------------------------------------------------------------------------------------------------------------------
So i think the problem is that the 'RecordStorage.GetRecord(Object id)' method only works with a Guid as input. And 'Library.GetRecord(String recordId)' gives it an String.
Can you please fix this? I need this for an project.
BUG! XSLT umbraco.contour:GetRecord('String id')
Hey guys,
I'm getting an error with the Contour in my xslt file.
Umbraco v 4.5
Contour v 1.0.12
--------------------------------------------------------------------------------------------------------------------------------------------------------------The xslt:
<xsl:variable name="record" select="umbraco.contour:GetRecord('62b8ac58-5b68-40d8-83f8-dc55429bd61a')"/>
The Error:
Comment author was deleted
Hey Niels, thanks for reporting this! I've just added the bug to our issue tracker and we'll look into it
Regards,
Tim
