  • Johan Roug 97 posts 153 karma points
    Aug 25, 2010 @ 11:53
    Johan Roug
    Double inputs
    I have installed contour, but I can see that in some cases things are rendered twize. Ex. a radiobuttonlist. Here I have added 2 items. but these two items are rendered 2 times in the list.
    The same happens on dropdownlists
  • Comment author was deleted
    Aug 25, 2010 @ 12:21
    That's weird, could you post a screenshot of your form design?
    Aug 25, 2010 @ 12:31
    Johan Roug
    Aug 25, 2010 @ 12:32
    Ok thanks, could you also show how this looks in the form designer? So you hit the edit items on 1 of the 2 items, do they only show 2 item?
    Regards,
    Tim
    Aug 25, 2010 @ 12:42
    Johan Roug
    Only 2 items
    Aug 25, 2010 @ 13:05
    Thanks! Just tested it and it works fine in my case.
    Could you give me some details on your setup (umbraco version, db engine, ..)?
    Tim
    Aug 25, 2010 @ 16:23
    Johan Roug
    Umbraco 4.5.1
    msSQL2005
    Aug 25, 2010 @ 16:43
    Thanks, could you check how many record you have in the UFPrevalues table?
  • Christian Palm 278 posts 273 karma points
    Aug 26, 2010 @ 09:24
    Christian Palm
    It's a MS SQL 2008 database
    There is 2 records
    14179356-524D-460C-A83A-76160935B50C   83BAA903-2E72-4F76-A748-B1EFE4ED9521    Kreditkort  0
    95C2FDD6-8855-4C83-A84B-C17E77EA81F5 83BAA903-2E72-4F76-A748-B1EFE4ED9521 Elektronisk faktura 1
    Aug 26, 2010 @ 09:31
    Christian Palm
    I found out why we get double
    In our master templates we have this
    <script language="C#" runat="server">
    private void Page_Init(object sender, EventArgs e)
    base.DataBind();
    </script>
    So I gues it's not a bug in Contour
    Aug 26, 2010 @ 09:44
    Great, thanks for the update!
