I've just upgraded to 4.5.2 and Contour is badly broken.
If I add an dropdownlist and save the form I get this error:
Line 262: </label>
Line 263: <div class="fieldControl">
Line 264: <%# RenderFieldPreview(((Umbraco.Forms.Core.Field)Container.DataItem)) %>
Line 265: <div class="fieldeditprevalues" <%# PreValueEdit(((Umbraco.Forms.Core.Field)Container.DataItem)) %>>
Line 266: <a href="#" onclick="javascript:ShowUpdatePrevaluesDialog('<%# ((Umbraco.Forms.Core.Field)Container.DataItem).Id %>')">
Source File: e:\webs\www.flugfelag.is_umbraco\usercontrols\umbracoContour\EditForm.ascx Line: 264
Umbraco.Forms.Core.Providers.Prevalues.Standard.GetPreValues(Field field) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.Core\Providers\Prevalues\Standard.cs:24
Umbraco.Forms.UI.Usercontrols.EditForm.RenderFieldPreview(Field f) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.UI\Usercontrols\EditForm.ascx.cs:205
ASP.usercontrols_umbracocontour_editform_ascx.__DataBind__control18(Object sender, EventArgs e) in e:\webs\www.flugfelag.is_umbraco\usercontrols\umbracoContour\EditForm.ascx:264
System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +303
And when doing preview :
Unable to find control with id '5877e6fc-da0f-4017-823e-2dbfff0011d9' that is associated with the Label 'label'.
[HttpException (0x80004005): Unable to find control with id '5877e6fc-da0f-4017-823e-2dbfff0011d9' that is associated with the Label 'label'.]
System.Web.UI.WebControls.Label.AddAttributesToRender(HtmlTextWriter writer) +11238970
System.Web.UI.WebControls.WebControl.RenderBeginTag(HtmlTextWriter writer) +32
System.Web.UI.WebControls.WebControl.Render(HtmlTextWriter writer) +32
I think you might have removed some Contour files during the upgrade, you can just download the update zip here:http://our.umbraco.org/projects/umbraco-pro/contour (bottom attached files)
And then simply extract that and place those files on your site
umbraco v 4.5.2.beta breaks Contour
Line 262: </label> Line 263: <div class="fieldControl"> Line 264: <%# RenderFieldPreview(((Umbraco.Forms.Core.Field)Container.DataItem)) %> Line 265: <div class="fieldeditprevalues" <%# PreValueEdit(((Umbraco.Forms.Core.Field)Container.DataItem)) %>> Line 266: <a href="#" onclick="javascript:ShowUpdatePrevaluesDialog('<%# ((Umbraco.Forms.Core.Field)Container.DataItem).Id %>')"> Source File: e:\webs\www.flugfelag.is_umbraco\usercontrols\umbracoContour\EditForm.ascx Line: 264 [NullReferenceException: Object reference not set to an instance of an object.] Umbraco.Forms.Core.Providers.Prevalues.Standard.GetPreValues(Field field) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.Core\Providers\Prevalues\Standard.cs:24 Umbraco.Forms.UI.Usercontrols.EditForm.RenderFieldPreview(Field f) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.UI\Usercontrols\EditForm.ascx.cs:205 ASP.usercontrols_umbracocontour_editform_ascx.__DataBind__control18(Object sender, EventArgs e) in e:\webs\www.flugfelag.is_umbraco\usercontrols\umbracoContour\EditForm.ascx:264 System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +303Can anyone help please....Comment author was deleted
Hi Stefan,
Hi Tim,
Thanks for your reply.
This does not work. The problem occurs after adding a dropdown field to the form.
Any ideas?
Stefan
Hi Stefan,
Does this always happen, so even when you create a new form and only add a dropdown field?
I think this must be a config issue, Contour works fine on our stage env. possible permissions issue?
Hi again,
I found out that if I have <distributedCall enable="true"> in the umbracoSettings.config then Contour breaks.
This works fine if it's set to false.
Can you please look into this?
Stefan
Hi again.
I think I found what's wrong.
If the server address that you are working on is not in the servers list in the distrubutedCall then this dosen't work.
As soon as I added the address everything works like a charm.
Best regards,
Stefan
