  • Niels Kristiansen 166 posts 382 karma points
    Sep 06, 2010 @ 08:50
    Niels Kristiansen
    import/export in Contour not working completly
    Hi again,
    I have tried to export a contour form, so it can be used for another form. After the export I place the .ucf correctly in the /umbraco/plugins/umbracoContour/templates folder and it actually shows up correctly in Umbraco administration.
    But I don't take all the form fields over in the new form. When I import til the formfields it ends with my radiobuttons "Hvem repræsentere du", but after them I actually have 4-5 formfields extra.
    I have placed the ucf file under this text, but I don't know if the export builder makes a error or is it me who's missing something?
    <Form xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns="UmbracoContour">
    <Name>Førstehjælp beg - 15.09.10 - Hundested</Name>
    <Created>2010-08-18T23:56:24.033</Created>
    <FieldIndicationType>NoIndicator</FieldIndicationType>
    <Indicator>&lt;span style="color: red"&gt;*&lt;/span&gt;</Indicator>
    <ShowValidationSummary>true</ShowValidationSummary>
    <HideFieldValidation>true</HideFieldValidation>
    <RequiredErrorMessage>{0} er påkrævet</RequiredErrorMessage>
    <InvalidErrorMessage>{0} er ikke korrekt</InvalidErrorMessage>
    <MessageOnSubmit>Thank you</MessageOnSubmit>
    <GoToPageOnSubmit>1346</GoToPageOnSubmit>
    <ManualApproval>true</ManualApproval>
    <Archived>false</Archived>
    <StoreRecordsLocally>true</StoreRecordsLocally>
    <DisableDefaultStylesheet>false</DisableDefaultStylesheet>
    <Pages>
    <Page>
    <FieldSets>
    <FieldSet>
    <Fields>
    <Field>
    <PreValues />
    <Caption>Fornavn</Caption>
    <ToolTip />
    <SortOrder>0</SortOrder>
    <PageIndex>0</PageIndex>
    <FieldsetIndex>0</FieldsetIndex>
    <Id>00000000-0000-0000-0000-000000000000</Id>
    <FieldSet>c0d6806e-7531-4c2d-bb6f-bf1ceb50d53a</FieldSet>
    <Form>999799a4-de84-43e9-a419-7aab63b0bdf0</Form>
    <FieldTypeId>3f92e01b-29e2-4a30-bf33-9df5580ed52c</FieldTypeId>
    <Mandatory>true</Mandatory>
    <RegEx />
    <RequiredErrorMessage />
    <InvalidErrorMessage />
    <PreValueSourceId>00000000-0000-0000-0000-000000000000</PreValueSourceId>
    <Settings />
    </Field>
    <Field>
    <PreValues />
    <Caption>Efternavn</Caption>
    <ToolTip />
    <SortOrder>1</SortOrder>
    <RegEx />
    <Settings />
    </Field>
    <Field>
    <PreValues />
    <Caption>Tlf. nr.</Caption>
    <ToolTip />
    <SortOrder>2</SortOrder>
    <Mandatory>false</Mandatory>
    <RegEx />
    <Settings />
    </Field>
    <Field>
    <PreValues />
    <Caption>E-mail</Caption>
    <ToolTip />
    <SortOrder>3</SortOrder>
    <RegEx>\w+([-+.']\w+)*@\w+([-.]\w+)*\.\w+([-.]\w+)*</RegEx>
    <Settings />
    </Field>
    <Field>
    <PreValues />
    <Caption>CPR-nr.</Caption>
    <ToolTip />
    <SortOrder>4</SortOrder>
    <RegEx />
    <Settings />
    </Field>
    <Field>
    <PreValues />
    <Caption>Særlig forhold, omk. forplejning</Caption>
    <ToolTip />
    <SortOrder>5</SortOrder>
    <RegEx />
    <Settings />
    </Field>
    </Fields>
    <Caption>Personlige informationer</Caption>
    <Page>1d9bd554-58c6-403e-ac04-543f6ac5a351</Page>
    </FieldSet>
    <FieldSet>
    <Fields>
    <Field>
    <PreValues>
    <PreValue>
    <Field>00000000-0000-0000-0000-000000000000</Field>
    <Value>Dig selv</Value>
    </PreValue>
    <PreValue>
    <Value>Offentlig virksomhed</Value>
    </PreValue>
    <PreValue>
    <Value>Privat virksomhed</Value>
    </PreValue>
    </PreValues>
    <Caption>Hvem repræsenter du</Caption>
    <ToolTip />
    <FieldsetIndex>1</FieldsetIndex>
    <FieldSet>d5fd6d53-9151-47f6-b6a1-b94a486ea299</FieldSet>
    <FieldTypeId>903df9b0-a78c-11de-9fc1-db7a56d89593</FieldTypeId>
    <RegEx />
    <Settings />
    </Field>
    <Field>
    <PreValues />
    <Caption>Firmanavn</Caption>
    <ToolTip />
    <RegEx />
    <Settings />
    </Field>
    <Field>
    <PreValues />
    <Caption>EAN- eller CVR-nr.</Caption>
    <ToolTip />
    <RegEx />
    <Settings />
    </Field>
    <Field>
    <PreValues />
    <Caption>Adresse</Caption>
    <ToolTip />
    <RegEx />
    <Settings />
    </Field>
    <Field>
    <PreValues />
    <Caption>Postnr.</Caption>
    <ToolTip />
    <RegEx />
    <Settings />
    </Field>
    <Field>
    <PreValues />
    <Caption>By</Caption>
    <ToolTip />
    <RegEx />
    <Settings />
    </Field>
    </Fields>
    <Caption>Adresse oplysninger</Caption>
    </FieldSet>
    </FieldSets>
    <Caption />
    </Page>
    </Pages>
    <DataSource>00000000-0000-0000-0000-000000000000</DataSource>
    <Id>999799a4-de84-43e9-a419-7aab63b0bdf0</Id>
    </Form>
    Kind regards,
    Niels
  • Comment author was deleted
    Sep 06, 2010 @ 08:56
    Hi Niels,
    Thanks for reporting this, will test your exported form and will get back with more info.
    Tim
    Sep 06, 2010 @ 09:10
    Niels Kristiansen
    Hi Tim,
    Thanks for the fast reply :)
    /Niels
    Sep 06, 2010 @ 15:45
    Bug fixed, if you upgrade to the latest work in progress version http://nightly.umbraco.org/Umbraco%20Contour/ (1.1.3 currently) it should work as expected
    (you'll simply need to replace the umbraco.forms.ui.dll if you are running 1.1.2).
    Regards,
    Tim
    Sep 11, 2010 @ 23:13
    Niels Kristiansen
    Hi Tim,
    Sorry for the late answer. It just worked as you said. Thanks for the help and the fast feedback with a solution :)
    Have a nice weekend.
    /Niels
