  • teus 42 posts 74 karma points
    Sep 07, 2010 @ 11:07
    teus
    Form entries large form(60 +) not showing
    Probably a known issue. I have a large form (62 fields). The biggest problem is that I cannot see anything in the form entries window. If I export (to HTML Table for instance) the submitted data is visible but this is not very userfriendly.
  • Comment author was deleted
    Sep 07, 2010 @ 13:33
    Would it be possible to provide a screenshot?
    Tim
    Sep 07, 2010 @ 14:12
    teus
    Sure, Also if I set the first dropdown to Submmited and press reload it keeps Processing untill the end of time ;-) I could also send you the ucf file of the form if you think it helps?
    Regards
    Sep 07, 2010 @ 14:18
    And does it only happen on this form? Also could you tell me what browser you are using.
    Tim
    Sep 07, 2010 @ 17:19
    teus
    No it also happens on another large form.
    I,m using firefox 3.6.8 on windows 7.  But viewing the entries in Chrome shows the same problem ; no entries.
    Other forms in the same site show there entries OK. Other strange thing I noticed is that the Forms title changes to FormsWorkflowsWorkflows
    Regards,
