  • Christian Palm 278 posts 273 karma points
    Sep 07, 2010 @ 14:40
    Christian Palm
    Using custom FieldSettingType on custom FieldType
    When using a custom FieldSettingType on a custom FieldType i get an exception.
    When I add the custom FieldType to a form the setting are working.
    But after the form has been saved in can not be opened since an exception are being thrown.
    It seems like it can not set the custom FieldSettingType
    Here is the exception
    [MissingMethodException: Method 'Upac.CampaignMonitor.ContourExtensions.ListsFieldType.Lists to include' not found.]
    System.RuntimeType.InvokeMember(String name, BindingFlags bindingFlags, Binder binder, Object target, Object[] providedArgs, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParams) +2172
    Umbraco.Forms.Core.FieldType.LoadSettings(List`1 settings) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.Core\FieldType.cs:86
    Umbraco.Forms.Data.Storage.FieldStorage.GetAllFields(FieldSet fieldset) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.Core\Data\FormStorage\FieldStorage.cs:96
    Umbraco.Forms.Data.Storage.FieldSetStorage.GetAllFieldSets(Page page) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.Core\Data\FormStorage\FieldSetStorage.cs:42
    Umbraco.Forms.Data.Storage.PageStorage.GetAllPages(Form form) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.Core\Data\FormStorage\PageStorage.cs:41
    Umbraco.Forms.Data.Storage.<>c__DisplayClass9.<GetForm>b__8() in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.Core\Data\FormStorage\FormStorage.cs:133
    umbraco.cms.businesslogic.cache.Cache.GetCacheItem(String cacheKey, Object syncLock, CacheItemPriority priority, CacheItemRemovedCallback refreshAction, CacheDependency cacheDependency, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem) +213
    umbraco.cms.businesslogic.cache.Cache.GetCacheItem(String cacheKey, Object syncLock, CacheItemPriority priority, CacheItemRemovedCallback refreshAction, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem) +121
    umbraco.cms.businesslogic.cache.Cache.GetCacheItem(String cacheKey, Object syncLock, CacheItemRemovedCallback refreshAction, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem) +118
    Umbraco.Forms.Core.Services.CacheService.GetCacheItem(String cacheKey, Object syncLock, TimeSpan timeout, GetCacheItemDelegate`1 getCacheItem) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.Core\Services\CacheService\CacheService.cs:62
    Umbraco.Forms.Data.Storage.FormStorage.GetForm(Guid id) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.Core\Data\FormStorage\FormStorage.cs:124
    Umbraco.Forms.UI.Pages.editForm.Page_Load(Object sender, EventArgs e) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.UI\Pages\editForm.aspx.cs:32
    System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
    System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
    System.Web.UI.Control.OnLoad(EventArgs e) +99
    umbraco.BasePages.BasePage.OnLoad(EventArgs e) +49
    System.Web.UI.Control.LoadRecursive() +50
    System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
    BTW the custom FieldSettingType works perfectly on my custom FieldPreValueSourceType
    The source code
    namespace Upac.CampaignMonitor.ContourExtensions
    using System;
    using System.Linq;
    using System.Web.UI.WebControls;
    using CampaignMonitorAPIWrapper.CampaignMonitorAPI;
    using Umbraco.Forms.Core;
    using Umbraco.Forms.Core.Controls;
    public class ListsFieldType : FieldType
    #region Fields
    private ValidateableCheckBoxList cbl;
    private List<object> value;
    #endregion Fields
    #region Constructors
    public ListsFieldType()
    base.Id = new Guid("{46172748-DF31-4c14-B4F3-300E355606A8}");
    base.Name = "Campaign Monitor Lists";
    base.Description = "Renders a checkbox list with mailinglists";
    this.Icon = "checkboxlist.png";
    this.DataType = FieldDataType.String;
    this.value = new List<object>();
    #endregion Constructors
    #region Properties
    public override WebControl Editor
    get
    cbl = new ValidateableCheckBoxList();
    cbl.CssClass = "checkboxlist";
    cbl.RepeatLayout = RepeatLayout.Flow;
    ListItem[] items = GetListItems();
    cbl.Items.AddRange(items);
    return cbl;
    set
    base.Editor = value;
    [Umbraco.Forms.Core.Attributes.Setting("Lists to include", description = "The selected lists the user can subscribe to", control = "Upac.CampaignMonitor.ContourExtensions.ListsFieldSetting", assembly = "Upac.CampaignMonitor")]
    public string ListsToInclude
    get;
    set;
    public override List<object> Values
    get
    if (cbl != null && cbl.SelectedIndex > -1)
    value.Clear();
    foreach (ListItem item in cbl.Items)
    if (item.Selected)
    value.Add(item.Value);
    return value;
    set
    this.value = value;
    #endregion Properties
    #region Methods
    public override string RenderPreview()
    return "<div class=\"checkboxlist\"></div>";
    // More to come
    public override string RenderPreviewWithPrevalues(List<object> prevalues)
    // More to come
    private ListItem[] GetListItems()
    List<ListItem> items = new List<ListItem>();
    if (!string.IsNullOrEmpty(ListsToInclude))
    string[] selectedValues = ListsToInclude.Split(",".ToCharArray(), StringSplitOptions.RemoveEmptyEntries);
    Api api = new Api();
    List<List> lists = api.GetLists();
    foreach (string selectedValue in selectedValues)
    List firstOrDefault = lists.FirstOrDefault(s => s.ListID == selectedValue);
    if (firstOrDefault != null)
    ListItem listItem = new ListItem(firstOrDefault.Name, firstOrDefault.ListID)
    Selected = value.Contains(firstOrDefault.ListID)
    items.Add(listItem);
    return items.ToArray();
    #endregion Methods
  • Comment author was deleted
    Sep 07, 2010 @ 14:45
    Hi Christian,
    I only tested it with a custom workflow (which worked), will check this out later today.
    Tim
    Sep 07, 2010 @ 15:27
    Ok found and fixed the problem,
    It's the /usercontrols/UmbracoContour/EditForm.ascx that needed an update
    you can download the update from our build server http://nightly.umbraco.org/Umbraco Contour/ (use the latest build of the work in progress version) and simply replace the /usercontrols/UmbracoContour/EditForm.ascx file
    Or you could update the file on line 303
    change
    ((System.Collections.Generic.KeyValuePair<string, Umbraco.Forms.Core.Attributes.Setting>)Container.DataItem).Value.GetName()
    to
    ((System.Collections.Generic.KeyValuePair<string, Umbraco.Forms.Core.Attributes.Setting>)Container.DataItem).Key
    Sep 08, 2010 @ 10:29
    Christian Palm
    Perfect
  • Peter Drayton 29 posts 49 karma points
    Oct 26, 2011 @ 16:23
    Peter Drayton
    I'm trying to do something similar with MailChimp, but I couldn't get your code to work.
    This line:
    is causing me issues in Visual Studio, it reports an Error saying
       Using the generic type 'System.Collections.Generic.List<T>' requires 1 type arguments
    Any help much appreciated.
