  • Johan Roug 97 posts 153 karma points
    Sep 14, 2010 @ 10:07
    Johan Roug
    Stylesheet
    It seems that contour puts its stylesheet inside the body tag. And this does not validate. How can I target the stylesheet to end up in the head?
  • Comment author was deleted
    Sep 14, 2010 @ 10:13
    Hi Johan,
    If you set a runat="server" attribute to your head it will be inside the head tag
    Or you could also add it manually (and disable that it get's added automaticly)
    Sep 14, 2010 @ 11:48
    Johan Roug
    That did the trick. Thanks
    <head runat="server" >
    Sep 14, 2010 @ 12:41
    Johan Roug
    Actually. It worked, but it also adds an extra title tag.
    Sep 14, 2010 @ 13:42
    Johan Roug
    I solved it by adding
    <title runat="server" visible="false" />
    just after the head tag
