Hi, I am in the process of upgrading a 4.x site to 4.5.2 and have run into an issue with Contour where none of my forms are showing in the tree and when I create anew form and try to add a field, the add field dialog (green background) simply flashes (shows and immediately disappears) on the screen and doesn't allow me to enter any data.
I just updated to Contour 1.2 (with the exception of adding the AjaxControlToolkit DLL.
Aha, so what about the directive in the 4.5.2 upgrade that suggest we remove AjaxControlToolkit? Are there other conflicts to worry about by adding the back?
Contour on 4.5.2
Have others seen issues with contour and 4.5.2?
Nik
Comment author was deleted
Hi Nik,
You'll need to add AjaxControlToolkit DLL
Tim
Thanks Tim!
-- Nik
Hi Nik,
Well since umbraco 4.5 umbraco doesn't have a dependency on Ajaxcontroltoolkit (hence you can remove it if you are upgrading)
But Contour does uses it
Tim
Got it, thanks for the confirmation!
-- Nik
