Hi All,
When I post to a url, Contour doesn't save a manually set value with a comma.
<input type="hidden" name="dbfields" value="356,357"/>
Is there a workaround to fix this?
Bas
Comment author was deleted
Hi Bas,
How did you add the hidden field? Are you using the hidden field fieldtype?
Hi Tim,
Thanks for the quik reply, this is a screenshot. It happens when I manually set a value.
So it doesn't save the value when it contains a ',' ?
Will add this to our issue tracker, a workaround could be to add a hidden field to the form and set the value there, then map the hidden field ...
(hidden field is available since contour 1.1, so not sure what version you are running)
That's right. I just upgraded my Contour installation, and the workaround is perfect. Thanks!
Field not saving
Hi All,
Bas
Hi Bas,
Hi Tim,
Hi Tim,
