    Sep 28, 2010 @ 11:04
    Ismail Mayat
    Contour custom workflow issue
    Guys,
    I am using contour 1.1 with umbraco 4.5.2 under .net40.  I have created a custom workflow type when i goto add workflow in contour i get error after selecting my workflow in the dropdown the error is:
    Source Error:
    Stack Trace:
       Umbraco.Forms.UI.Dialogs.editWorkflowDialog.LoadSettings(Form form) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.UI\Dialogs\editWorkflowDialog.aspx.cs:110
       Umbraco.Forms.UI.Dialogs.editWorkflowDialog.Page_Load(Object sender, EventArgs e) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.UI\Dialogs\editWorkflowDialog.aspx.cs:69
       System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
       System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
       System.Web.UI.Control.OnLoad(EventArgs e) +91
       umbraco.BasePages.BasePage.OnLoad(EventArgs e) +49
       System.Web.UI.Control.LoadRecursive() +74
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2207
    Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.1
    It seems to have issue when loadingsettings which is where the properties that are publicly accessible and decorated are accessed that code looks like
            [Setting("EmailLookUpField", description = "Enter the receiver email lookup field for DMC", control = "Contour.SharedSource.FieldSetting.TextField")]
            public string EmailLookUpField { get; set; }
            [Setting("DocumentEmailAddressFieldAlias", description = "Email field alias in document that contains email address", control = "Contour.SharedSource.FieldSetting.TextField")]
            public string DocumentEmailAddressFieldAlias { get; set; }
            [Setting("Subject", description = "Enter the subject", control = "Contour.SharedSource.FieldSetting.TextField")]
            public string Subject { get; set; }
            [Setting("Message", description = "Enter the intro message", control = "Contour.SharedSource.FieldSetting.TextArea")]
            public string Message { get; set; }
    Anyone any ideas?
    Regards
    Ismail
  • Comment author was deleted
    Sep 28, 2010 @ 11:14
    Hi Ismail why are you using Contour.SharedSource.FieldSetting.TextField and Contour.SharedSource.FieldSetting.TextArea ?
    You can simply use Umbraco.Forms.Core.FieldSetting.TextField and Umbraco.Forms.Core.FieldSetting.TextArea
    Or if you do want to use field setting types from another assembly (then Umbraco.Forms.Core) you must add , assembly = "Contour.SharedSource"
    Sep 28, 2010 @ 11:18
    Ismail Mayat
    Tim,
    "why are you using Contour.SharedSource.FieldSetting.TextField " DOH it was a case of clipboard inheritance.  Updated as per your suggestion and it all works nicely.
    Many thanks
    Ismail
    Ow and custom fieldsetting types are only possible from version 1.1.3 and up
