  • Johan Roug 97 posts 153 karma points
    Sep 28, 2010 @ 13:50
    Johan Roug
    Contour validationerror
    I found another contour validation error.
    As one can see in the image below, I have made a checkbox list. The label and inputs for the checkbox are correct, but for some reason, there is made a label that refers to the span (for, has the same value as if on span). This should not be a label, but maybe a div, p, span, og something else.
  • Comment author was deleted
    Sep 30, 2010 @ 09:38
    If you want complete control over the markup check out http://our.umbraco.org/projects/website-utilities/cultiv-restcontour
    Regards,
    Tim
    Sep 30, 2010 @ 15:35
    Johan Roug
    Contour is great, we just wish for it to validate. Not full control.
    /Johan
