has anyone tried installing contour 1.1.3 on umbraco versioned 4.0.3? i wondered if the license still works? i have a umbraco4.0.3 instance with contour 1.0.8 installed, they worked as fine as expected. but when i upgraded to 1.1.3, contour keeps prompting for license, even though it already exists in \bin folder. i have crawled a few articles, and had no luck on that. if you have successfully installed contour 1.1.3 on umbraco 4.0.3. please advise me. by the way, what i mean by "upgraded" is to uninstall 1.0.8 and install 1.1.3 via package\umbraco pro.
I've got 1.1.3 running fine on 4.0.x. On one site I did have a similar problem, I fixed it by deleting the license file, and then re-importing it using the import license wizard from the top of the Contour home page while it was in trial mode, That sorted it out for me.
contour 1.1.3 on Umrbaco 4.0.3
hi gurus,
any input will be appreciated.
Comment author was deleted
Contour 1.1.3 should run fine on Umbraco 4.0.3 , what you could try is to remove the license and then fetch it trough the Contour dashboard.
Regards,
Tim
yes.. i have tried that and its still in trial mode.
@Stone,
Could you contact us trough the license support on umbraco.org (should be available from your profile). With the details on the domain.
Regards,
Tim
