Works the same as documents and media, just go to the member section, go to member types, select your type and add properties to it. And in the API you can again get or set the property with .getProperty("myThing").Value.
Aah, wait I didn't see it was in the contour forum, sorry!
Ehm, of course you could set some of that user data in a cookie and use the bracket syntax for cookies in the default value field, or you could try to make a custom fieltType that would get the member property value for you (I'd prefer the last option).
Would be nice to have a dropdown in the default value field which was populated with all of the member properties so you could choose from them. Would make a killer addition to the Contour Contrib project.. hmmm interesting!
What you could do currently is set some session variables when the member logs in and then use the bracket syntax on the default value property to populate fields with these values.
There hasn't by any chance been any update to Tim's idea to enable e.g. {member.firstname} as a default value for a form? Would be tremendously useful!
On another note, we are a NY based web dev. company looking to build a network of Umbraco developers worldwide. Please let me know if you would be interested in discussing.
@lori advertising is not allowed in forum posts, there's a jobs forum and you can postbyour ads there. Do note that your account will be disabled and your posts will be deleted if you post more ads anywhere else. Thanks.
Default values from logged in member? (feature question)
Is it possible to make a form fill fields with values from for example the logged in members properties?
Found this http://our.umbraco.org/forum/umbraco-pro/contour/9771-Default-Form-Values about the topic, might be the best options avaliable, dunno how hard it is to create a field type of my own tho. Perhaps a piece of cake?
Regards
/Jonas
There's no XML cache for members by the way, it will involve an API call.
Hi Sebastiaan,
Yes, but in Contour - how do I use that value as a default one in a form field, guess your answer means it is a piece of a cake? *diving into it*
Aha:
http://our.umbraco.org/projects/umbraco-contour-shared-source
Comment author was deleted
Hi Jonas,
More details on the default values feature: http://umbraco.org/documentation/videos/umbraco-pro/contour/contour-11-default-values
I will however look into extending the bracket syntax so it's also possible to fetch member values (so you could simply do {member.firstname})
@Tim oooh, shiny!
Does anyone know if this is possible yet?
Hi Jonas:
Lori
Lori at appdrenaline dot com
@dan should be possible now according to the release notes :
http://our.umbraco.org/projects/umbraco-pro/contour
Yup it is possible in 1.1.9 , I'll post some more details soon.
basicly you set the default value to {member.propertyalias}
Thanks guys. Works like a dream. I'm saving the member id as a label i an Umbraco doc then I can get all the properties I need from that.
Some details on the update: http://www.nibble.be/?p=106
Thanks Tim, for another great feature on Contour. The more I work with it the better it gets :-)
