Getting selected VALUE from PreValue Sources using Bracket Syntax
I have a prevalue source which contains name and ID values... at the end of my form submission, i'd like to display the selected value to the user, however using the {fieldname} syntax is showing the ID of the selected item, not the value.
In the form results, the value displays correctly.. is there a trick to getting the value instead of the ID?
Cheers
Greg
