  • Martin Griffiths 826 posts 1269 karma points c-trib
    Oct 05, 2010 @ 15:06
    Martin Griffiths
    Contour problem with the poet patch
    We've just noticed our contour forms are now redirecting to the poet patch custom error page upon submit.
    Can anyone confirm similar difficulties?
    I cant think of any way around it short of removing the patch altogether.
    We're running an instance in Umbraco 4.0.4.2 with Examine applied to it.
    Oct 05, 2010 @ 15:22
    Ismail Mayat
    I think that may be becuase in .net when you do redirect it generates an httpexception to stop the current page thus allowing redirect.  Have tried the actual windows patch http://weblogs.asp.net/scottgu/archive/2010/09/28/asp-net-security-update-now-available.aspx thus in theory not needing poet patch?
    regards
    Ismail
    Oct 05, 2010 @ 15:28
    Martin Griffiths
    Hi Ismail
    With a little further digging we've realised that its look more like a directory URLs issue.
    In the settings tab of contour you can redirect the success to a seperate page, and its 404ing.
    Of course with DirectoryURLs turned on its "success" instead of "success.aspx"
    So the question really is does DirectoryURLs work properly with Contour!
  • Tim 1193 posts 2675 karma points MVP 5x c-trib
    Oct 13, 2010 @ 13:16
    Tim
    Hiya,
    It should do, I've got a number of sites with Contour forms that work fine with the DirectoryUrls feature enables.
