  • Ole Thorsager 5 posts 25 karma points
    Oct 11, 2010 @ 08:37
    Ole Thorsager
    Problem retrieving a Record object
    I am trying to approve a record from code (when I get a callback from epay)
    But an error occur when I try to create the Record object. Below is a sample of the process (would be nice if I could get a record by ust applying the recordId)
    XPathNodeIterator iterator = Umbraco.Forms.Library.GetRecord(recordId);
    XmlNode node = ((IHasXmlNode)iterator.Current).GetNode();
    // Below throws a Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx).
    Record record = Record.CreateFromXmlNode(node);
    RecordService service = new RecordService(record);
    service.Approve();
    service.Dispose();
  • Comment author was deleted
    Oct 11, 2010 @ 10:01
    Hi could you try fetching it by using the RecordStorage object
    SHould be something in the line of
    RecordStorage rs = new RecordStorage();
    Record r = rs.GetRecord(guid);
    rs.dispose();
  • Tim 1193 posts 2675 karma points MVP 4x c-trib
    Oct 11, 2010 @ 10:02
    Tim
    Could you post the error that you're getting please?
    Ignore that, should have read the post properly! What @Tim said!
    Oct 11, 2010 @ 10:25
    Ole Thorsager
    That was exactly what I needed, thanks alot for the fast advice :)
  • Yan 36 posts 56 karma points
    Nov 12, 2010 @ 16:36
    Yan
    Hi Ole,  how you get the guid (record id ) first palce? Did you have custom work flow after submit the form, and save the record id to session or ? Try to understand how to pass the record id to the payment gateway? I try to do the same thing but not sure how. thanks in advance
    Nov 12, 2010 @ 17:03
    Ole Thorsager
    Hi Yan
    Yes I have a custom workflow on submit which among other things saves the recordid in a separate order table.
    Nov 12, 2010 @ 17:58
    Yan
    Hi Ole, Is it possible share your workflow source or advice how to save the recordId in the workflow. Thanks,
  • Harald Ulriksen 207 posts 249 karma points
    Nov 13, 2010 @ 13:18
    Harald Ulriksen
    Yan,
    I have a sample workflow which saves the id to the Context.Items. See http://harald.ulriksen.net/2010/6/2/getting-id-of-newly-created-contour-record.aspx
    I've added the code sample here
    namespace Ulriksen.Silhouette
        public class ContextUpdateWorkflow : WorkflowType
            public override Umbraco.Forms.Core.Enums.WorkflowExecutionStatus Execute(Record record, RecordEventArgs e)
                e.Context.Items[ItemKey] = record.Id;
                return Umbraco.Forms.Core.Enums.WorkflowExecutionStatus.Completed;
            public override List<Exception> ValidateSettings()
                return new List<Exception>();
            [Umbraco.Forms.Core.Attributes.Setting("Item key",
              description = "Key used when adding the record Id to the Context.Items ",
              control = "Umbraco.Forms.Core.FieldSetting.TextField")]
            public string ItemKey { get; set; }
            public ContextUpdateWorkflow()
                this.Name = "Store record id in context";
                this.Id = new Guid("15d2f92f-2134-43fb-bd13-35120f36997a");
                this.Description = "This will add the record id of the newly created record to the context with key recordId";
    Harald
    Nov 15, 2010 @ 02:17
    Yan
    Thank you very much, Harald! Great help!
    Yan
