When I use a FieldSetting.FieldPicker on a custom fieldtype i get an exception.
[NullReferenceException: Object reference not set to an instance of an object.] Umbraco.Forms.Core.FieldSetting.FieldPicker.RenderControl(Setting sender, Form form) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.Core\Common\FieldSettingType\FieldPicker.cs:34 Umbraco.Forms.UI.Usercontrols.EditForm.RenderFieldTypeSpecificSettings(Object sender, RepeaterItemEventArgs e) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.UI\Usercontrols\EditForm.ascx.cs:128 System.Web.UI.WebControls.Repeater.OnItemDataBound(RepeaterItemEventArgs e) +108 System.Web.UI.WebControls.Repeater.CreateItem(Int32 itemIndex, ListItemType itemType, Boolean dataBind, Object dataItem) +136 System.Web.UI.WebControls.Repeater.CreateControlHierarchy(Boolean useDataSource) +443 System.Web.UI.WebControls.Repeater.OnDataBinding(EventArgs e) +51 System.Web.UI.WebControls.Repeater.DataBind() +75 Umbraco.Forms.UI.Usercontrols.EditForm.RenderFieldTypeSettings(Object sender, RepeaterItemEventArgs e) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.UI\Usercontrols\EditForm.ascx.cs:114 System.Web.UI.WebControls.Repeater.OnItemDataBound(RepeaterItemEventArgs e) +108 System.Web.UI.WebControls.Repeater.CreateItem(Int32 itemIndex, ListItemType itemType, Boolean dataBind, Object dataItem) +136 System.Web.UI.WebControls.Repeater.CreateControlHierarchy(Boolean useDataSource) +443 System.Web.UI.WebControls.Repeater.OnDataBinding(EventArgs e) +51 System.Web.UI.WebControls.Repeater.DataBind() +75 Umbraco.Forms.UI.Usercontrols.EditForm.Page_Load(Object sender, EventArgs e) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.UI\Usercontrols\EditForm.ascx.cs:68 System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14 System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35 System.Web.UI.Control.OnLoad(EventArgs e) +99 System.Web.UI.Control.LoadRecursive() +50 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Control.LoadRecursive() +141 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Is this a bug?
Comment author was deleted
Will test and let you know
Fixed in maitenance release coming this week (Contour 1.1.4)
Can not use FieldSetting.FieldPicker on custom FieldType?
Is this a bug?
