returns prevalues from another prevalue of the same type.
I have a custom prevaluetype which takes an Xpath string and a node id as settings. I have configured 2 prevalues using this type, one called FOO and one called BAR with different xpath. I have 2 forms A and B. Form A has radiobuttons with prevalue FOO and form B has radiobuttons with prevalues from BAR.
I load form A using the API (and dispose of the form storage). I then try to access prevalues for the field using
Checking PreValueSource.Name, Form.AllFields[7].PreValueSource.Name, returns FOO while Form.AllFields[7].PreValueSource.Type.FieldPreValueSource.Name returns BAR.
I tried messing around with that. It seems to always want me to pass in field though. I don't have a field to pass in.
var pss = new Umbraco.Forms.Data.Storage.PrevalueSourceStorage();
var ps = pss.GetPrevalueSource(new Guid("a693970f-c74e-4c1b-8130-f8f2fc5900f2")); // guid for PrevalueSource
var pv = ps.Type.GetPreValues(WANTS A CONTOUR FIELD);
API not returning correct prevalues for Field
I'm trying to retrieve prevalues from a Field using the API based on http://our.umbraco.org/forum/umbraco-pro/contour/12438-Getting-prevalues-through-the-API
using
however this returns prevalues from BAR not FOO.
This is on Contour version 1.1.3
Harald
Comment author was deleted
Hi Harald,
You should do an explicit load settings first, f.PreValueSource.Type.LoadSettings(f.PreValueSource);
Regards,
Tim
Is there a way to load prevalues directly from the source without having to get them from a field?
Sure there is a prevalue storage
Check Umbraco.Forms.Data.Storage.PrevalueSourceStorage
@Tim
var pss = new Umbraco.Forms.Data.Storage.PrevalueSourceStorage(); var ps = pss.GetPrevalueSource(new Guid("a693970f-c74e-4c1b-8130-f8f2fc5900f2")); // guid for PrevalueSource var pv = ps.Type.GetPreValues(WANTS A CONTOUR FIELD);is working on a reply...
