  • Tim 1193 posts 2675 karma points MVP 5x c-trib
    Nov 03, 2010 @ 14:02
    Tim
    Bug in RecordsViewer GetRecords Method
    There appears to be a bug in the GetRecords method of the RecordsViewer. If you call it and pass in the page id of the page you want the records for, you get all of the records for the form, not just the ones for the umbraco page that you specified. All of the Record objects that are returned are missing the umbraco page id, this apears to be because the code in the Record.CreateFromXMLRecord() method doesn't actually add it to the object.
    If you want to try and repo, create a form, add some approved entries from several pages, and then run the following code (note, you'll need to modify this to get it to work, as its an excerpt from a bigger page):
      int pageId = Convert.ToInt32(lstEvents.SelectedValue);
      List<Umbraco.Forms.Core.Enums.FormState> states = new List<Umbraco.Forms.Core.Enums.FormState>();
      states.Add(Umbraco.Forms.Core.Enums.FormState.Approved);
      FormStorage fs = new FormStorage();
      Form form = fs.GetForm(formId);
      fs.Dispose();
      RecordsViewer rv = new RecordsViewer();
      List<Record> list = rv.GetRecords(10000, pageId, form, Sorting.ascending, states);
      foreach (Record pie in list)
       Response.Write(pie.UmbracoPageId.ToString() + "<br/>");
      rv.Dispose();
    All of the page ids are zero, and you'll see that all of the entries are returned, not just the ones for the specified page.
    Nov 05, 2010 @ 11:45
    Tim
    After a bit more testing, ALL of the methods in the RecordsViewer that get Record objects are afflicted by this issue (presumably because they all call the CreateFromXMLRecord() method. There was an older version of Contour that you could actualy open in Reflector and I've had a dig around, and if the code hasn't changed, it's missing the line to add the UmbracoPageId (most of the other fields seem to be added).
    Another thing I spotted is that if you call the  GetRecords(int maxNumber, int page, Form form) method, it doesn't actually honour the page that you pass in it just passed in the form.
    Hope that helps!
    Nov 13, 2010 @ 21:04
    Tim
    Is there any chance of getting this into 1.1.4?
  • Comment author was deleted
    Nov 15, 2010 @ 08:49
    Yup working on 1.1.4 this week, will make sure this get's fixed
    Nov 15, 2010 @ 13:18
    Hi Tim,
    Looks like GetPagedXmlRecords is the method you are looking for
    Nov 15, 2010 @ 13:20
    The getrecords methods are older methods that aren't used anymore
    Nov 15, 2010 @ 13:38
    Tim
    Ahhh, ok. I couldn't get the PagedXmlRecords to bind to a datagrid properly, so was using the ones that returned records!
    Nov 15, 2010 @ 13:44
    Try enclosing the call with XmlHelper.XmlToRecords()
    Nov 15, 2010 @ 13:45
    Tim
    Awesome, I'll give that a go this afternoon! Thanks.
