Hi, i'm getting a strange issue in Contour - when adding a new field in IE it is creating duplicates.
For example, open a form and add a new field of any type. This works ok, but if you add another field after this then it creates 2 fields. Click to add another and it creates 3, and so on.
The number of fields that get created each time keeps increasing until you navigate away and come back to the form.
I'm also experiencing this bug using IE 8.0 running 4.5.2 on iis7
And the original poster has it perfectly. You create a field, then you create another field, but instead of 1 new field, you get 2. And then you create another field and instead of 1 new field, you get 3.
The work-around I'm currently using is to save the form everytime you add a field
Wierd IE bug when adding fields
I was just about to post this as well. I'm having the same issue in IE 8
Comment author was deleted
That's strange, will see if I can reproduce the error.
Regards,
Tim
Tim,
A little info: I'm using 4.5.2 (4.0) on iis 7.5
browser: ie 8.0.7600.16385
Fixed in maintenance release coming this week
