  • robert coyle 14 posts 34 karma points
    Nov 05, 2010 @ 12:44
    robert coyle
    Gap Between Fields
    Hi Community,
    I recently spent the 100 bucks and bought Contour! A lot of lolly for a form generator buy hey ho. Now I having awful trouble styling my form! Its like this... when I create my form theres a big gap between each field. A "big gap". So if shrunk this gap using CSS and resetting the height of these:
    .textfield
    .dropdownlist
    .businessaddress TEXTAREA
    .descriptionofservices TEXTAREA
    However how when I submit my form with  required fields missing the red error text that normally appears in the space i removed is now on top of the fields (making a mess). Basically that gap I removed was the space for the error message to appear!
    Is there some easy way of setting the form so that there are no large gaps and the error messages (for required fields not filled in) appears in a better location? Im thinking I need to get rid of the error message altogether and just have contour add a red "*" to the end of this field. But either way I dont want to go hacking at the code as the mighty coutour might have an easy way of solving my problem.
    Id love to hear any ideas ... have anyone crossed this bridge? Thanks a million. Robert
  • Comment author was deleted
    Nov 05, 2010 @ 13:48
    Hi Robert,
    Could you post a screenshot of the problem?
  • wolulcmit 357 posts 693 karma points
    Nov 05, 2010 @ 14:26
    wolulcmit
    in your css try:
    span.contourError, #contour br{display:none}
    should get rid of the gaps you're talking about without having to hardcode any heights or anything ugly like that.
    - Tim
    Nov 05, 2010 @ 15:41
    robert coyle
    Hi Wolulcmit,
    Thats worked perfectly! I thought that would make my error message disssappear too but no!
    Thanks both of you for your reply. Karma bubble coming your way.
    Nov 05, 2010 @ 15:45
    wolulcmit
    Nice One! the error messages get set to display:block again when the javascript kicks in (when user tries to submit the form).
