  • Mike Chambers 636 posts 1253 karma points c-trib
    Nov 08, 2010 @ 15:43
    Mike Chambers
    default email regexp doesn't allow .co.uk addresses
    the default regexp for email validaton on the send email template is a little too restrictive.standard send email - email regex validation doens't allow .co.uk domains.
    ^\w+@[a-zA-Z_]+?\.[a-zA-Z]{2,3}$
    only allows for a single 2 or 3 letter
    so will fail for user.name@domain.co.uk :-(
    MS email validation is \w+([-+.']\w+)*@\w+([-.]\w+)*\.\w+([-.]\w+)*
    Nov 08, 2010 @ 16:54
    Ismail Mayat
    Mike,
    I got caught with that the other day, replaced it with ms one and it worked.
    Regards
    Ismail
    Nov 08, 2010 @ 16:56
    Mike Chambers
    Yep I did to... just posted here for the contour devs to see, as sending from the "spotted a bug page" of the contour branch or umbraco just disappears into the ether...
    thanks.
  • Donald St. Martin 83 posts 128 karma points
    Nov 22, 2010 @ 15:41
    Donald St. Martin
    In case anyone lands on this topic that needs an updated regex, I use:
    [a-z0-9!#$%&'*+/=?^_`{|}~-]+(?:\.[a-z0-9!#$%&'*+/=?^_`{|}~-]+)*@(?:[a-z0-9](?:[a-z0-9-]*[a-z0-9])?\.)+[a-z0-9](?:[a-z0-9-]*[a-z0-9])?
    Donald
  • Sam 184 posts 209 karma points
    May 17, 2011 @ 21:47
    Sam
    Thanks Donald,
    That was a great help :)
    Sam.
