Problems Installing Contour 1.1.4 On Umbraco 4.5.2
When I run the installer from the "Umbraco Pro" section in the CMS, I get the following error(s):
Installed the database
Datatype could not be installed + System.Collections.Generic.KeyNotFoundException:
The given key was not present in the dictionary.
at System.ThrowHelper.ThrowKeyNotFoundException()
at System.Collections.Generic.Dictionary`2.get_Item(TKey key)
at
umbraco.cms.businesslogic.datatype.controls.Factory.GetNewObject(Guid
DataEditorId)
at umbraco.cms.businesslogic.datatype.controls.Factory.DataType(Guid
DataTypeId)
at
umbraco.cms.businesslogic.datatype.DataTypeDefinition.get_DataType()
at Umbraco.Forms.UI.Usercontrols.Installer.Page_Load(Object sender,
EventArgs e) in
d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.UI\Usercontrols\Installer.ascx.cs:line
48
Updated /umbraco/config/create/ui.xml
Added dashboard to Contour application
web.config could not be updated + System.NullReferenceException:
EventArgs e) in
181
Addded Formpicker macro control
Updated english language file with Contour keys
As far as I know, directory permissions seem ok. I would like to try the manual install now but have no idea where to find Files.zip and the SQL install scripts (mentioned in the install guide) can be found!
Do you see the contour section, since it looks like most steps completed, the only thing you should be missing is the form picker datatype (and an update to the web.config but that isn't critical)
Following the above, I can then click on "Open Umbraco Contour" which shows me the options such as "Register Contour", "Create" etc. As you say, there's no form picker datatype. Can you recommend what I should do next to get it working?
System.Collections.Generic.KeyNotFoundException: The given key was not present in the dictionary. at System.ThrowHelper.ThrowKeyNotFoundException() at System.Collections.Generic.Dictionary`2.get_Item(TKey key) at umbraco.cms.businesslogic.datatype.controls.Factory.GetNewObject(Guid DataEditorId) at umbraco.cms.businesslogic.datatype.controls.Factory.DataType(Guid DataTypeId) at umbraco.cms.businesslogic.datatype.DataTypeDefinition.get_DataType() at Umbraco.Forms.UI.Usercontrols.Installer.Page_Load(Object sender, EventArgs e) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.UI\Usercontrols\Installer.ascx.cs:line 48
System.NullReferenceException: Object reference not set to an instance of an object. at Umbraco.Forms.UI.Usercontrols.Installer.Page_Load(Object sender, EventArgs e) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.UI\Usercontrols\Installer.ascx.cs:line 181
Comment author was deleted
Hi Duncan,
Hi Tim,
Many thanks,
Duncan.
