We run "compeitions" on our site and have a basic entry form name, phone, email etc which are consistent through all competitions. In additon this this we a textbox with a question like "Find the question for this competition on page 136 in latest issue of..."
So my question is with contour would I need to create a new contour form (so competition answers can be seperated) for each competition? and could the answer regex come from a node property or does it need to be manually added when creating the form?
Just you could export and import the form (so you have a copy) and then update your question. Or you can remove the old question and add the new one (old data won't be deleted).
For the regex, a page property can be used if you use the special parameter syntax (check the docs).
Coutour Questions.
Hello.
Thanks.
Comment author was deleted
Regards,
Tim
