  • bob baty-barr 1180 posts 1294 karma points MVP
    Dec 03, 2010 @ 16:42
    bob baty-barr
    How would I.... ranking items 1-5
    I have the need to create a question that asks the form user to rank the following items 1-5 but only one item can be number 1, etc.
    in a previous - non contour form - i had text fields to just plug in the number and validated that only one of each rank existed.
    would love to migrate this to contour... any thoughts?
  • Chris Koiak 700 posts 2626 karma points
    Dec 03, 2010 @ 16:56
    Chris Koiak
    Maybe a custom bit of JS on the page that checks for this? Therefore no changes to your contour form.
    Dec 03, 2010 @ 17:01
    bob baty-barr
    Chris, that is totally an option... so you are thinking using the matrix add-on with the radials and make sure that only one slection per ranking exists???
    Dec 03, 2010 @ 17:05
    Chris Koiak
    Bob, I've no idea because I've never used Contour... just thought I'd throw an idea in :-D
    Dec 03, 2010 @ 17:08
    bob baty-barr
    well, if you haven't used contour... i totally recommend you give it a whirl -- it TOTALLY ROCKS!
  • Jason Prothero 422 posts 1243 karma points MVP 2x c-trib
    Dec 03, 2010 @ 17:36
    Jason Prothero
    Interesting problem.
    You could make a custom Contour field type to help with the visual piece, and a custom Contour event handler to validate that only one of each rank was selected.  That would give you some assurance in case they had javascript turned off.
    But it would be nice to overlay a javascript piece on to that as well to make the user experience better.
