  • Fergus Davidson 309 posts 588 karma points
    Dec 07, 2010 @ 12:58
    Fergus Davidson
    Workflow 'post to webpage' not working - BUG?
    hi
    i have a form containing a dropdown list of options as one of the fields. this list is built up using the standard contour method, adding values.
    i have two items in the workflow, both on submit:
     - email: this works fine, all fields in the email are submittd as text and are readable
     - post to webpage: this seems to post the GUID for the dropdown list, not the readable text
    i presume that as the email picks this up correctly, that this is either a feature or a bug.
    any ideas on how i can sort this out? is there an alternative way to reference the text in the dropdown, rather than the GUID value?
    any help would be appreciated
