  • Sander Houttekier 114 posts 163 karma points
    Dec 13, 2010 @ 16:29
    Sander Houttekier
    editing existing radiobutton items on a form does not work
    after saving an existing form
    and working on it the day afterwards, 2 more options needed to be added to the radiobuttonlist
    yet, clicking the "edit Items" link below that formfield,
    nothing happens
    if i open firebug it gives this error upon clicking the link:
    "uncaught exception: Syntax error, unrecognized expression: »"   not sure why, but without a reference to what file or script it is in.
    anyone had this before?
    umbraco version 4.0.2.1  (possibly soon 4.5.2 but that is still under discussion with the client (.net version issues and such)
  • Comment author was deleted
    Dec 13, 2010 @ 17:05
    @Sander, what version of Contour are you running?
    Dec 13, 2010 @ 17:06
    Also does one of the items contain the » char ?
    Dec 13, 2010 @ 18:19
    Sander Houttekier
    package version: 1.1.3
    the >> char : yes   removing that would solve it?
    best regards
    Sander
    Dec 13, 2010 @ 18:20
    @Sander, try removing the char, and see if that fixes it
    Dec 13, 2010 @ 20:35
    Sander Houttekier
    removing the >> was in fact the solution
    should this character be escaped or something
    I'm going to tell the client he should not use it for now, but thats somehow ignoring the problem :)
    in any case, good to know what exactly caused it
    Dec 14, 2010 @ 08:14
    Yup only a temp solution for now, added the issue to our but tracker and we'll look at it for the next maintenance release.
    Tim
