  • Kevon K. Hayes 255 posts 281 karma points
    Dec 13, 2010 @ 23:12
    Kevon K. Hayes
    Content node not visible for my Editors after Contour Upgrade
    Umbraco 4.5.2 | SVR 2008 R2 Ent.
    I recently upgraded to Contour 1.1.4.1 and somehow the Content Tree wont render.  The tree will render for my admin account though.  I looked at this thread here: http://our.umbraco.org/forum/ourumb-dev-forum/bugs/5343-Content-Tree-empty however I'm using AjaxControlToolkit.dll v1.0.10920.0
  • Comment author was deleted
    Dec 14, 2010 @ 08:33
    Hi Kevon,
    For you editors do they have a start node set? Try resetting that and saving the user...
    Tim
    Dec 14, 2010 @ 20:25
    Kevon K. Hayes
    Tim,
    Yes they have a start node I reset this and stil no mas/no go.  Do you know of any issues with 2008 R2?  At any rate...the only fix that has worked was to create a new user account.  The user accounts created after the 1.1.4 install can see the content tree just fine.  Can I cleanly "delete" an existing umbraco account from SQL or is there other dependencies I need to worry about?, (do you have a pre-existing SQL script)  I must to keep the same usernames which is why I need to do this via SQL.
    Dec 14, 2010 @ 22:52
    Kevon K. Hayes
    Tim, this was my fault I copied a conflicting dll to the bin directory that rendered the content tree useless.
