  • Daniel Horn 319 posts 344 karma points
    Dec 14, 2010 @ 13:51
    Daniel Horn
    Defining an id on input fields
    How do I define the id of the fields i add to my forms in contour?
  • Comment author was deleted
    Dec 15, 2010 @ 08:43
    Hi Daniel,
    It's not possible to define the id of the fields (Contour does add a lot of classes so for styling you should be able to use that)
    Or why do you need to set the id?
