  • joju 7 posts 27 karma points
    Dec 29, 2010 @ 09:24
    joju
    custom hyperlink control in contour
    hi there, i'm trying to add a hypelink control to contour but the problem is the  generated html tag seems to get encoded when it is rendered on the page... also what's appearing is just this... < id="ctl00_ctl00_ctl00_ContentPlaceHolderDefault_BrinkMasterContentPlaceHolder_RenderForm_9_rpFieldsets_ctl00_rpFields_ctl10_c4436d94_913f_4529_9b91_fd4071e1c619" href="usercontrols/umbracoContour/#"> gdfgdfgdfg
    Dec 29, 2010 @ 09:35
    Ismail Mayat
    joju,
    How exactly are you adding the hyperlink control, are you modifying the renderform ascx ?
    Regards
    Ismail
    Dec 29, 2010 @ 09:42
    joju
    i've added a custom fieldtype by adding this class as stated in contour's developer docs
    public class UmbracoContourAnchor:FieldType
            public System.Web.UI.WebControls.HyperLink hl;
            public List
    Dec 29, 2010 @ 09:54
    Ismail Mayat
    Where you have line
     hl.NavigateUrl = NavigateUrl;
    just for now try and hardcode a url there e.g "http://www.yahoo.com" what do you get?
    Regards
    Ismail
    Dec 29, 2010 @ 09:57
    joju
    same thing... < id="ctl03_rpFieldsets_ctl00_rpFields_ctl11_bdae1ca2_3470_4a1b_b20a_fa3c83ebd330" href="http://www.yahoo.com"> adasdasd
    adasdasd is the innertext or text attribute of the hyperlink control
