"A prevalue source type can also implement edit capabilities so new items can be added/updated/deleted directly from the form editor" from the developer guide.
In http://our.umbraco.org/forum/umbraco-pro/contour/6180-Edit-data-from-front-end (a year old) Per PJ says "It is currently not possible to fetch contour records from memberKey, will add that to the feature suggestion list, as it's a good idea. If you know the record key however (you could save it on the member) you can retrieve the record and edit it through the api."
Thanks for the tip Tim. Is it possible to load a record in a Contour form as Laurence asks from a query string or programmatically load any record into the form being rendered? If so can you provide a code snippet?
I'm trying to use Contour to render forms and capture data etc., but I'm using a data source instead of the built in Contour data storage, so I would like to just inject the data and capture it when it is being submitted. Is that possible?
Edits in Contour forms?
Is it possible to let members (outside of the admin section that is) be able to edit and delete their previously entered form posts with Contour?
Jonas
I think I just have to dive into it.
Comment author was deleted
Hi Jonas,
You can place the renderform macro in edit mode, if you then supply it a record id you will be able to edit the record.
For deleting you'll need to build something custom (should be super simple).
Tim
Can this record Id be provided as a query string? If so, what is the format?
I've tried, ?recordGuid=
Hi everybody
Thanks a lot in advance :)
Kim
