  • Paul Marden 235 posts 338 karma points MVP 3x c-trib
    Jan 10, 2011 @ 22:56
    Paul Marden
    Problem loading up contour after install
    Just trying reposting, as it didn't seem to work a moment ago.
    I've just installed the latest version of contour direct from the repository on Friday into a 4.5.2 instance and get the following error.
    Ideas?
    Could not load file or assembly 'Umbraco.Licensing, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
    Exception Details: System.IO.FileNotFoundException: Could not load file or assembly 'Umbraco.Licensing, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
    Source Error:
    Assembly Load Trace: The following information can be helpful to determine why the assembly 'Umbraco.Licensing, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' could not be loaded.
    WRN: Assembly binding logging is turned OFF.
    To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
    Note: There is some performance penalty associated with assembly bind failure logging.
    To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
    Stack Trace:
    [FileNotFoundException: Could not load file or assembly 'Umbraco.Licensing, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.]
       Umbraco.Forms.Core.Licensing.IsTrial() in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.Core\Licensing\Licensing.cs:34
       Umbraco.Forms.Core.Configuration.get_IsTrial() in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.Core\Configuration.cs:41
       Umbraco.Forms.UI.Dashboard.FormsDashboard.Page_Load(Object sender, EventArgs e) in d:\TeamCity\buildAgent\work\e4473b9ec9597356\Umbraco.Forms.UI\Dashboard\FormsDashboard.ascx.cs:34
       System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
       System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
       System.Web.UI.Control.OnLoad(EventArgs e) +99
       System.Web.UI.Control.LoadRecursive() +50
       System.Web.UI.Control.LoadRecursive() +141
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
    Version Information: Microsoft .NET Framework Version:2.0.50727.3615; ASP.NET Version:2.0.50727.3618
    Jan 10, 2011 @ 23:23
    Paul Marden
    Interestingly falling back to Contour 1.1.4 seems to have fixed the problem, without any other changes.  Still unclear why I can't use 1.1.4.1
  • Tim 1193 posts 2675 karma points MVP 5x c-trib
    Jan 11, 2011 @ 13:16
    Tim
    It looks like the umbraco licensing DLL is missing? You can get the DLL from the latest builds repository here (choose your version of Contour and then select the most recent update): http://nightly.umbraco.org/Umbraco%20Contour/ the file you are looking for is called "Umbraco.Licensing.dll"
    Hope that helps!
