  • Carlos 338 posts 472 karma points
    Jan 11, 2011 @ 23:56
    Carlos
    Contour export output
    Is there a way to export the Contour email when submitted as an Excel spreadsheet attachment?
    If so how?
    Or do we have to dig into the code?
    Thanks in advance.
  • Comment author was deleted
    Jan 13, 2011 @ 16:43
    Hi Carlos,
    Yes you'll have to setup a custom workflow type but you can use the contour shared sourcecode as a starting point
    http://our.umbraco.org/projects/umbraco-contour-shared-source
    Regards,
    Tim
  • joe huang 7 posts 26 karma points
    Aug 16, 2011 @ 15:00
    joe huang
    I am getttig error saying "the type or namespace name WorkflowExecutionStatus could not be found" when I override WorkflowExecutionStatus as other sample in this sourcecode to inherent the workflow.  I have  referred to Umbraco.Forms.Core.  do I have to refer any other dll?
    Thanks you very much
