Error: Added data does not match known number of columns
I've removed a form step from one of my forms, and now I'm trying to view the entries and get an alert saying "added data does not match known number of columns".
Okay, fine, so I deleted all of the entries from the database.. But I'm still getting the same error. What should I do? Don't want to recreate the form & workflow, so much work (it's a pretty long form).
Oh, also, as soon as I add the extra step and field again (field can have a different name), the entries overview works again. But I don't want the step because then the workflow doesn't trigger after submit.
Not sure what happened but this problem seems to have "magically" fixed itself. It's possible that this was fixed after a reboot of the computer, not sure. I'm just glad it works now :-)
Comment author was deleted
And does the entries export work ?
Nope, I only get the headers, two of which are empty (the first and the last).
Thanks for the info, will try to reproduce and fix
Alright, FYI: recently upgraded from 1.1.2 (or maybe 1.1.1) to 1.1.4 and today to 1.1.5. Problem occured in both 4 and 5.
There was one extra step with one field.
If you can't reproduce I could send you my solution! :)
Have you had a chance to look at this yet? Thanks in advance!
Ah great! Might have been a cache issue then
