  • Laurence Gillian 600 posts 1219 karma points
    Jan 23, 2011 @ 23:19
    Laurence Gillian
    Contour - Form Entries Filter
    Hope everyone's had a lovely weekend and is well.
    I've got an issue occurring on a fresh install of Contour, which is being used to submit a fairly lengthy form, around 30 fields.
    When I try and view the submitted records for say more than a 24 hour period (which would normally see 8 records created) it runs very slow, and most times just hangs of 'Processing' with no resolve, and occasionally returns the data, but after 10+ minute wait.
    Is this a known problem with Contour, I'm running the database on a separate server with Microsoft SQL2008 which also serves several other Umbraco powered websites.
    Is there anything useful in terms of testing I could do to try and find a resolution for this problems, and for others in the future if they experience this.
    The form submission is also quite slow (around 10 seconds), could these be an indicator of an underlying issue?
    Any ideas for a fix, or starting points to investigating this would be great as I need to access this information ;)
    All the best, Laurie x
    Jan 23, 2011 @ 23:23
    Laurence Gillian
    Further to this, sometimes this results in the application pool crashing. Lx
  • Comment author was deleted
    Jan 24, 2011 @ 08:52
    Hi Laurence, 10 seconds for a single form submissions, that's huge ...  Does the umbraco backend also perform this slow ?
    Jan 24, 2011 @ 12:56
    Laurence Gillian
    Umbraco backend is fairly speedy, trying to get my head around why this is happening now. Will let you know if I find anything, Lau
  • Jeavon Leopold 3074 posts 13632 karma points MVP 12x admin c-trib
    Jan 24, 2011 @ 16:26
    Jeavon Leopold
    I have also experienced this issue, we have an installation of Contour with two forms, one of the forms doesn't have this issue and another one does, as soon as I choose year or decade it stalls on "processing", however when set on month there is no problem paging through all the records (there are only 40).
    Tim, if a screen capture would help with this, let me know.
    Jan 24, 2011 @ 16:53
    Thanks for the extra details, will try to reproduce
    Jan 24, 2011 @ 16:54
    @Laurence, does it happen with all forms in that installation?
    Jan 25, 2011 @ 13:30
    Laurence Gillian
    Not sure, the site is only driving one form.
    Will replicate on to local and setup a few different forms and see if I can get this problem again.
    I maybe shooting in the dark, but could it be that it is a client side issue (e.g caused by the browser), not responding properly, which then causes the request to hang and crash? I say this as performance is considerably better in Firefox than it has been in Safari.
    Does Contour query the DB directly, or does it use a XML cache? /Laux
    Jan 26, 2011 @ 12:40
    Laurence Gillian
    Further to this, although performance on this install is slow than I would like, there is an issue when using Safari on the Mac. Will post back version, etc (it is not the latest version for sure).
    Laux
    Jan 27, 2011 @ 15:54
    Jeavon Leopold
    The form which we have an issue with with has 42 submissions in the last year, in order to get the "processing...." frozen message, we can do two things.
    1. First choose year (or decade) and reload, then choose 50 more more in the show menu (10, or 25 work with no problem and allow paging)
    2. First choose 50 or more in the show menu then choose year (decade)
    The other form in this installation of Contour has 113 entries in the last year and all filter options work fine.
    Jeavon
    Feb 03, 2011 @ 16:58
    Laurence Gillian
    Querying via XSLT also causes performance issues. /Lau
    Feb 03, 2011 @ 17:04
    Laurence Gillian
    Using the export function on the top left of the form throws an System.Web.HttpException: Request timed out.
    Feb 07, 2011 @ 17:25
    Laurence Gillian
    Okay I've had a chance to look at the issue in a tiny bit more detail.
    The issue is caused by either large amounts of entries or columns
    A very dodgy work around is turning all the columns off, loading in the data and then turning one on at a time. With a form which has 48 fields, I can load around 5 columns at around 300 records before Contour crashes the database. Even this takes around 5 minutes to complete.
    Guys what can I do to help? I've now had a chance to test this on 2 different systems and its not a system unique bug. I am more than happy to sink time into trying to fix this and improving Contour.
    Lx
    Feb 07, 2011 @ 17:42
    Laurence Gillian
    So I would say this issue would be with;
    /plugins/umbracoContour/webservices/records.aspx?
    Feb 10, 2011 @ 10:02
    Hi Laurence, would it be possible to share your db ? That way I can try to find out where the performance issue is located.
    You can just mail the details to tg at umbraco dot dk
    Thanks!
    Tim
    Feb 25, 2011 @ 12:41
    Jeavon Leopold
    Hi Tim,
    Just wondering if there has been any progress with this (we have a client who is slightly frustrated about not being able to export their form data)?
    Jeavon
    Feb 25, 2011 @ 13:03
    @Jeavon,
    Yes to resolve this simply roll back  /umbraco/plugins/umbracocontour/xslt/excel.xslt to this version:
    http://dl.dropbox.com/u/14228187/excel.xslt
    Tim
    Feb 25, 2011 @ 13:08
    Jeavon Leopold
    Hi Tim,
    That doesn't seem to have helped in our case, still get a frozen "Processing......."?
    Jeavon
    Feb 25, 2011 @ 15:35
    @Jeavon,
    That's the records viewer, the fix is for the export (if you hit the export button in the menu)
    Feb 25, 2011 @ 18:05
    Laurence Gillian
    Another big and lovely ask would be that the export following the order of the fields on the form, not some random order!
    Guessing I can do this in that XSLT though? Will have a look on Monday.
    Lx
    Feb 28, 2011 @ 09:38
    Yeah think it's a-z currently, but can be done in xslt, will see if I can easly add a new export option
    Feb 28, 2011 @ 10:59
    Laurence Gillian
    Yep it is, been having a look over the weekend myself.
    Am I right in thinking the reason why the XSLT extensions for Contour are slow (on long & complex forms) is because its directly querying the database?
    Would it not make sense to use some sort of helper which created a XML Cache of the data? Then you could quickly manipulate the data.
    Just a thought really, Laurie
    Feb 28, 2011 @ 12:04
    Jeavon Leopold
    @Tim I'm not sure that helps as we can't get a view that displays all the records within Contour as it gets stuck? However as a short term solution, we added the excel.xslt to a hidden page and it generated the csv values for all records on the page without any issue so we were able to copy and paste it and send the complete data to our client.
    Jeavon
    Feb 28, 2011 @ 12:09
    Laurence Gillian
    Jeavon, not sure if it helps. But Safari reports the script as being unresponsive and asks if you want to kill it, if you keep clicking continue to keep the script alive, even though the browser is completely locked up, you can eventually get all the records up on the page.
    I think its just a case of the query taking a long time to return the data. (hence my comment above above)
    Laux
    Feb 28, 2011 @ 15:29
    Jeavon Leopold
    That is strange, I don't get the alert about killing it in Safari (Win 7) it just waits and waits.......
    Mar 10, 2011 @ 17:12
    Laurence Gillian
    Just a quick bit of feedback, a present the excel.xslt sorts the fields in the form alphabetically.
    Is there any end-user who would actually want the output like that? Surely it needs to reflect the sort order on the form? (or have a switch to allow easy changing)
    On a completely separate note, it would be damn cool if you could import/update from a csv/xml/excel file.
    Mar 10, 2011 @ 17:23
    Thanks for the suggestions Laurence, I'll add this to our issue list.
    Good point about the sort order in the export( I'll try to add one in the next maintenance release).
    Mar 10, 2011 @ 17:31
    Laurence Gillian
    Also updated mine to export the GUID. That way if you are doing fancy shenanigans in Excel you've got something unique to reference against. Lx
    May 05, 2011 @ 13:27
    Jeavon Leopold
    Hi Laurence and Tim,
    After a very drawn out forensic investigation we have tracked the freezing issue back to a solitary slash entered into a text field during testing! We manually updated the xml in the UFRecordsXml table to replace the content with the slash to remove it and now all filtering options work again! There must be a tricky little bug in there somewhere for you Tim!
    Regards,
    Jeavon
    May 05, 2011 @ 14:16
    Thanks for the info Jeavon, will reproduce and fix!
    May 05, 2011 @ 15:13
    Jeavon Leopold
    No problem Tim, if you need a db backup please let me know.
  • Douglas Ludlow 210 posts 366 karma points
    Dec 05, 2011 @ 19:04
    Douglas Ludlow
    Not to revive a dead thread or anything, but what's the status on the column sort option? It makes more sense to keep it sorted in the order that appears on the form.
    One example where this is applicable is on a form that has more than one field with the same name, ie "Other". Sorted alphabetically, the values get lumped together and are not read in context.
