Hi, is there a way to check all entries in the backend in one click without having to tick each one one by one?
Not that I'm aware of sadly! If you ask Tim G nicely though, there's a chance something like this might make it into a future update, it shouldn't be too hard to add I'd have thought.......
:P
Comment author was deleted
Yup will add this to our issue tracker, should be an easy one to add
Cheers,Tim
Thank you!
Hi Tim
Any news about this? Has it been included in the latest versions? If not, when is it sceduled to be included?
Looks like it was also mentioned back in February 2012.
http://our.umbraco.org/forum/umbraco-pro/contour/28139-Select-All-Form-Entries-and-delete-for-cleanup
Cheers
Henrik
Contour backend : check all entries
:P
Tim
Thank you!
Hi Tim
Cheers
Henrik
