  • Ansar 181 posts 291 karma points
    Feb 17, 2011 @ 22:16
    Ansar
    Custom Field Type - Text box with Add More using JQuery
    Hi All,
    I have a requirement to craete a new Field Type fpor contour.. basic functionality of the field type is a textbox with Add More button.. which allows the user to add more textboxes to enter data..
    Something similar to this http://www.mkyong.com/wp-content/uploads/jQuery/jQuery-add-remove-textbox.html
    When the user click submit button all the value should be saved as comma seperated value to database..
    I am very new to Umbraco.. any help on this matter is greatly apprecaited..
    Regards,
    Anz
    Feb 18, 2011 @ 17:55
    Ansar
    Hi All,
    I am almost ready with first version of the above mentioned control..
    Can anyone please tell me whats the purpose of RenderPreview and RenderPreviewWithPrevalues functions?
    Best Regards,
    Anz
  • Dave Woestenborghs 3504 posts 12135 karma points MVP 10x admin c-trib
    Feb 25, 2011 @ 11:01
    Dave Woestenborghs
    Hi Anz,
    These methods are called to render the field in the form design mode.
    The RenderPreview let's you define a markup for the field to display in designer
    The RenderPreview let's you define a markup with prevalues if your fieldtype supports prevalues.
    I recommend you have a look at the sharde source : http://our.umbraco.org/projects/developer-tools/umbraco-contour-shared-source
    You will find some examples there. Look at the dropdown to see examples of both methods.
