  • Adam Jenkin 71 posts 226 karma points
    Feb 18, 2011 @ 17:14
    Adam Jenkin
    Labels not displayed when form is rendered.
    I have created a standard "contact us" form with Contour.
    When I preview the form with contour, the labels are shown correctly.
    When I plave the form onto a page with using a macro, no labels are rendered.
    The rendered HTML does not contain the labels at all.
    This is an Umbraco 4.6.1 website using Contour 1.5.1. I have changed the defualt language on the website to English (New Zealand) if that matters at all.
    Please help!
    Adam
    Feb 18, 2011 @ 17:25
    Adam Jenkin
    Update: The labels are rendered but with a class of "invisible". I guess I need to determine how to stop the Invisible class be applied to the label.
  • Dave Woestenborghs 3504 posts 12135 karma points MVP 10x admin c-trib
    Feb 25, 2011 @ 11:25
    Dave Woestenborghs
    Hi Adam,
    The problem is the skin you are using. The labels will get the class invisble applied through a javascript function. You can find it in /scripts/Designit_Green/Designit_Green.js
    Dave
    Feb 25, 2011 @ 18:08
    Adam Jenkin
    Thanks Dawoe - Now that im using my own templates (without the Designit_Green.js) the form is looking correct.
