  • Vishal Chintawar 13 posts 33 karma points
    Mar 04, 2011 @ 20:47
    Vishal Chintawar
    Multiple Workflows on submit doesn't work
    i have a contact form which i want to email and then forward user to a thankyou page. i added 2 workflows in the section "When the form has been Submitted", but user is never forwarded to the thank you page. i do get the email. i tried http, non http, relative and absolute url. nothing works. tried different sort order, doesn't work. i even tried only forwarding to a page using adding only workflow, Post form to URL. that doesn't work either.
    1. is there a bug when using post form to URL?
    2. can you have multiple workflows on submit?
    i can achieve the forwarding by changing the form settings, but i want to use workflow so i can get email and post some data to another page.
  • Comment author was deleted
    Mar 07, 2011 @ 09:14
    Hi Vishal,
    Workflows will execute in the background so the post form to url workflow will do the post but in the background, if you want to redirect to a page on submit use the form settings
    Tim
    Mar 07, 2011 @ 15:02
    Vishal Chintawar
    thanks for the clarification! just to make sure, using redirect, workflows will be executed and then the page will redirect, correct?
    Mar 07, 2011 @ 17:30
    @Vishal correct
    Mar 07, 2011 @ 17:40
    Vishal Chintawar
    thanks tim. i hava another query regarding the contact forms. i have replied to your post here http://our.umbraco.org/forum/umbraco-pro/contour/8097-Skip-form-step-based-on-entered-value
    if you can clarify that, then i will be able to make desicion on which route to take. thanks again, and contour rocks man!!
