  • Ansar 181 posts 291 karma points
    Mar 28, 2011 @ 08:20
    Ansar
    Contour data and XSLT issue...
    I am trying to print data from contour using XSLT..
    As per the contour documenation sample.. following code shoudl work..
    <xsl:for-each select="umbraco.contour:GetRecord('c0b46ad4-aa34-41d8-99e0-6c891dfb5275')/uformrecord/fields/child::*">
    <xsl:sort select="fullname" order="ascending"/>
    <h4>
    <xsl:value-of select="
    fullname"/>
    </h4>
    </xsl:for-each>
    but its not printing anything..
    I am sure the data is available and the folliwing code is printing complete data as a big string...
    <xsl:variable name="records" select="umbraco.contour:GetRecord('c0b46ad4-aa34-41d8-99e0-6c891dfb5275')" />
    <xsl:value-of select="$records" />
    Can anyone please help me to make this work..
    Thanks and Best Regards,
    Ansar
    Mar 28, 2011 @ 10:48
    Hi Ansar
    What does the XML structure that gets outputted look like?
    Instead of <xsl:value-of select="$records" /> try using a xsl:copy-of instead and write the content out in a <textarea> - Then you can see the whole XML structure. You're probably not macthing the XML correctly.
    Try doing this
    <textarea>
    <xsl:copy-of select="$records" />
    </textarea>
    What does the XML look like?
    Mar 28, 2011 @ 11:21
    Ansar
    Hi Jan,
    Thank you for the reply.. I have created a sample page here http://skgep1.aspgulf.net/z_test.aspx
    The 1st table shows all entries and the textarea shows one specific record..
    Regards,
    Ansar
    Mar 28, 2011 @ 16:08
    Ansar
    Hi Jan,
    Thanks.. I got it...
    <xsl:variable name="records1" select="umbraco.contour:GetRecord('c0b46ad4-aa34-41d8-99e0-6c891dfb5275')//fields" />
    <xsl:value-of select="$records1/comment/values/value" /><br />
     <xsl:value-of select="$records1/name/values/value" />
    Regards,
    Ansar
