  • billiblu 37 posts 62 karma points
    Mar 30, 2011 @ 16:18
    billiblu
    Problems Installing Contour 1.1.6 On Umbraco 4.7
    Tt the end of the installation this message appared:
        * Installed the database
        * Added the forms datatype
        * /umbraco/config/create/ui.xml could not be updated +
          System.UnauthorizedAccessException: Access to the path 'C:\inetpub\wwwroot\umbraco\config\create\ui.xml' is denied. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share) at System.Xml.XmlDocument.Save(String filename) at Umbraco.Forms.UI.Usercontrols.Installer.Page_Load(Object sender, EventArgs e) in d:\TeamCity6\buildAgent\work\278191fcc80f7b16\Umbraco.Forms.UI\Usercontrols\Installer.ascx.cs:line 101
        * Added dashboard to Contour application
        * Updated web.config to use correct asp.net ajax assemblies
        * Addded Formpicker macro control
        * English language file could not be updated +
          System.UnauthorizedAccessException: Access to the path 'C:\inetpub\wwwroot\umbraco\config\lang\en.xml' is denied. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share) at System.Xml.XmlDocument.Save(String filename) at Umbraco.Forms.UI.Usercontrols.Installer.Page_Load(Object sender, EventArgs e) in d:\TeamCity6\buildAgent\work\278191fcc80f7b16\Umbraco.Forms.UI\Usercontrols\Installer.ascx.cs:line 222
    In my "C:\inetpub\wwwroot\umbraco\config\" there are not "create" and "lang" folder.
    Contour section is visible.
    Can you help me to solve the problem?
    Davide
    Mar 30, 2011 @ 16:30
    billiblu
    Sorry... I solved the problem.
    The securuty settings on umbraco\config folder were wrong.
    I have properly configured security settings and install again  Contour
    Now it work correctly.
    Davide
  • Comment author was deleted
    Mar 31, 2011 @ 10:12
    Great!
