  • billiblu 37 posts 62 karma points
    Apr 01, 2011 @ 10:15
    billiblu
    Send e-mail using field as recipient
    is it possible to add a workflow action to send an e-mail using a specific field (classic e-mail of my customer) as recipient?
    for me is important so send a confirmation e-mail to user.
    Davide
  • Yannick Smits 321 posts 718 karma points
    Apr 01, 2011 @ 10:30
    Yannick Smits
    Yes this is possible. Have a look at this package.
  • Comment author was deleted
    Apr 01, 2011 @ 10:38
    Yes it is, you can simply use the special syntax
    Say you have a field with the caption Email, where the user enters his email
    Then when setting the workflow you can set the receiver email to this email by using this syntax: {email}
    More details on the syntax can be found in the developer docs
    Tim
  • Paul Stewart 50 posts 71 karma points
    May 18, 2011 @ 14:43
    Paul Stewart
    @Tim how do you apply that to the subject line? I am using 2 of the same workflows but sending to 2 people,
    1. User submitted email
    2. my email for records
    But I want to use dictionary items in the subject line as for example.
    #Client Subject - Thank you for registering
    #Host Subject - Response from your website.
    I've looked at different topics but cant seem to find the solution.
    May 20, 2011 @ 11:31
    Well it should be #dictionaryItemKey but you can't add any other text to it then...
