  • Justin Grimm 56 posts 138 karma points
    Apr 08, 2011 @ 18:20
    Justin Grimm
    Contour Installation KeyNotFoundException
    Purchased a license for Contour and trying to install it on my latest Umbraco project (umbraco v 4.7.0.RC)
    Getting this error:
    • Installed the database
    • Datatype could not be installed +
      System.Collections.Generic.KeyNotFoundException: The given key was not present in the dictionary. at umbraco.cms.businesslogic.datatype.controls.Factory.GetNewObject(Guid DataEditorId) at umbraco.cms.businesslogic.datatype.DataTypeDefinition.get_DataType() at Umbraco.Forms.UI.Usercontrols.Installer.Page_Load(Object sender, EventArgs e) in d:\TeamCity6\buildAgent\work\278191fcc80f7b16\Umbraco.Forms.UI\Usercontrols\Installer.ascx.cs:line 50
    • Updated /umbraco/config/create/ui.xml
    • Added dashboard to Contour application
    • Updated web.config to use correct asp.net ajax assemblies
    • Addded Formpicker macro control
    • Updated english language file with Contour keys
    Any thoughts would be much appreciated?
  • Comment author was deleted
    Apr 11, 2011 @ 12:31
    Not sure what is wrong, but seems it only affected the datatype.
    Could you check if it added the datatype? Should be one called form picker
    Apr 11, 2011 @ 21:20
    Justin Grimm
    Hi Tim,
    The form picker datatype did not get created.
  • Dan Okkels Brendstrup 101 posts 197 karma points
    Apr 12, 2011 @ 16:33
    I'm getting the same error installing v1.1.6 on Umbraco 4.7.0. Mentioned it in this thread as well, which documents the same error in an earlier version.
    Could it perhaps have something to do with the fact that the installer is referencing a file on a non-existing d: drive?
    Apr 12, 2011 @ 16:36
    Ok will look into the issue have done a lot of installs and never seen the error.
    But it seems to only affect the creation of the datatype, contour section should still perform fine
    Apr 12, 2011 @ 16:40
    Alright, I hope you'll be able to pinpoint it — and let me know if you need any more system info.
    If it is indeed only a datatype that is missing (and it appears to be), would it be easy enough to create manually? If so, what are its properties?
    Apr 14, 2011 @ 15:02
    Yup simply create a new one and select form picker as the render control and that's it
