  • Dimitris Chrysomallis 21 posts 73 karma points
    Apr 13, 2011 @ 14:40
    Setting OLEDB DataSource for Oracle gives NullReferenceException
    We are  trying to connect to an oracle db through oledb:
    Provider=MSDAORA.1;Data Source=OracleDataSource;Password=password;User ID=userid
    The error is:
    • Object reference not set to an instance of an object.
    Is this a known issue?
    Thank you
  • Comment author was deleted
    Apr 13, 2011 @ 14:42
    Hi Dimitris,
    Well we haven't tested with an oracle db, and the error message doesn't provide a lot of details.
    Did you set the rest of the settings (table name, ..)?
    Apr 13, 2011 @ 15:13
    Hi Tim,
    Yes I did set a tablename. It seems to make a connection, since if I set a bogus table name I get an oracle error:
    Table does not exist. ORA-00942: table or view does not
    exist
    With prevalue sources I get a different oracle error:
    One or more errors occurred during processing of command. ORA-00923: FROM
    keyword not found where expected
    Also, I'm on umbraco 4.6.1 and contour version 1.1.5.
    OLEDB Connections to sql server work as expected.
    Apr 13, 2011 @ 15:25
    Hi Dimitris,
    I'm affraid that oracle isn't supported then.
    What you could do is write your own custom prevaluesource and datasource type since it seems to default ones can't deal with oracle
    You can find the sourcecode for the default providers here: http://our.umbraco.org/projects/developer-tools/umbraco-contour-shared-source
    Apr 13, 2011 @ 15:52
    Ok then!
    Thank you very much.
    Dimitris
